Kolibri
blackbird225's Avatar
Unhappy 69 911 gauges snafu
Sigh... So I just spent $1150 getting my gauges done at North Hollywood. They came out beautiful.. But... I sent all 5 gauges, but the left two for oil, temp, etc were from a 70+ early car. They already had the extra bits I wanted- real measurements, etc. So, I get them out of the box and realize in an instant.. they don't have screw posts on the rear for my dash like the others do... I pulled out the old two gauges and they of course do have them. These gauges are exactly the same size but came with a huge rubber o-ring around the outside. That's not going to fit in my 69 dash, right? I mean, at some point Porsche realized what a pain it was to get those gauges in and out and went to this compression o-ring style- so did they also widen the diameter of the hole? Or should they fit with the big O-rings? Sure seems like it's about 2-4 mm too small to fit in there.
So if that's the case, what would you do? I thought about drilling a hole in the gauge, cut a long metric screw's head off and using it like a threaded rod. Then I will get shavings all in my new high dollar gauges
Cant believe I never checked the fitment of these two before I had them redone.
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
1975 Volvo C303 TGBII
1967 Honda S90, 1975 CB550
Old 05-22-2014, 02:33 PM
You do not need to drill holes, you can use the threaded holes of these screws, insert a threded rod with jam nuts and will work like the studs in the original gauge.
Old 05-22-2014, 03:05 PM
pors1968's Avatar
The lettering is slightly different from 69 than 72+
Old 05-22-2014, 05:11 PM
A couple of turns of friction tape or vinyl electrical tape, just behind the bezel lip, will give enough bite for the press-in gauges to fit securely in the opening.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-23-2014, 07:41 AM
I Wonder
mgro1959's Avatar
If you ever have to drill and control the shavings coat the end of the bit with grease. This should keep most of the shavings from endering a hold. Thanks Rob
Old 05-23-2014, 11:40 PM
