-   -   Driver Power Window Issue (http://forums.pelicanparts.com/porsche-911-technical-forum/804594-driver-power-window-issue.html)
tailwind22 04-04-2014 07:07 AM
88 911 driver side power window quit working. Passenger window operates from both switches. When I activate the switch I can hear a clicking down in the vicinity of the motor. I did try a new switch and get the same result. Would the clicking indicate a ground issue or most likely a motor issue? Looking for anyone with past experiences here.
calimedeiros 04-04-2014 07:10 AM
Sounds like you have power at your window motor u need to get in there and check things out sounds like your window regulator broke
