-   -   Dizzy rebuild (http://forums.pelicanparts.com/porsche-911-technical-forum/804603-dizzy-rebuild.html)
Wew 04-04-2014 08:01 AM
Dizzy rebuild
Group, Posting a new topic here hoping to attract a couple of the experts who can give me input regarding the positioning of my dizzy.
Engine is dropped and cleaning up.
I go to manually crank the engine (clockwise) and the dizzy moves counter clockwise. Thats good. I go to line up the timing mark "Z1"and the notch on the body of the dizzy with the rotor and interesting how it will not line up. So I am not sure if previous owner put it in incorrectly or I am just not reading my instructions correctly.
There is also a boat load of crud that I hi lighted as well. Not sure where that comes from or what causes that.
Either way it looks like it's a good thing I am doing the dizzy rebuild. Any input or thoughts regarding the dizzy position and should I adjust the rotor to line up with the notch on the dizzy body when I reinstall it?
Thanks for the input,
Gary
http://forums.pelicanparts.com/uploa...1396623634.jpg
http://forums.pelicanparts.com/uploa...1396623643.jpg
boyt911sc 04-04-2014 08:10 AM
Ignition distributor alignment.......
Gary,
You could turn the ignition distributor to line-up the rotor close to the scribed marker. Look down at the stud that holds the distibutor in place. Set it as close as you get it now. The final adjustment should be done with the engine running using an inductive timing light.
Tony
wolds 04-04-2014 08:12 AM
OK, so I think whoever installed the dizzy is off one or more teeth. Pull it and reorient it so that it lines up with mark after you clean/check the dizzy. Than go ahead and set your timing again. Warren
timmy2 04-04-2014 08:22 AM
Looks like it is off by one tooth as mentioned above. Pull it watching were it moves to as you remove it and move it a little towards the notch and re-insert. Might take a couple of tries to get it right.
Wew 04-04-2014 09:08 AM
Yes, I was thinking that is was off as well. And it doesn't surprise me based on some of the stuff I have come across while restoring.
Thanks a bunch gents. Will report back soon.
Gary
cmcfaul 04-04-2014 12:45 PM
On my motor that is not TDC but 5 degrees before TDC. Mark to the right is TDC
just saying. Not sure what engine this is.
Chris
73 911 E
Reiver 04-04-2014 01:10 PM
If that is the Z1 mark then he's doing it correctly.
boyt911sc 04-04-2014 06:39 PM
Are you sure of this?
Chris
73 911 E
Chris,
Tony
timmy2 04-04-2014 08:11 PM
Dizzy rebuild
IIRC he is working on a '78 3.0
Looks to be TDC to me.
TibetanT 04-04-2014 08:36 PM
I am no expert, but I agree with this assessment. The mark to the right looks to be the timing mark for 5 degrees BTDC.
I would check to see if both valves on #1 are closed, they should be if this is truly TDC, correct?
whiskyb 04-05-2014 05:45 AM
You might also find they changed the orientation of the plug wires on the cap bu one position to compensate
Wew 04-06-2014 09:00 PM
Ugly find
Should I trash the guts and start from scratch? I doi have the rebuild kit from partsklassic but it is so bad in there, not sure if it is worth piecing back together. Also the small piece on the bottom that holds on of the springs snapped off as well. Not sure if that is replaceable or repairable.
Calling on all experts to see if its worth salvaging. If yes or no, what else should be replaced and where are the parts sourced?
Thanks all,
Gary
http://forums.pelicanparts.com/uploa...1396843028.jpg
http://forums.pelicanparts.com/uploa...1396843085.jpg
http://forums.pelicanparts.com/uploa...1396843112.jpg
http://forums.pelicanparts.com/uploa...1396843130.jpg
http://forums.pelicanparts.com/uploa...1396843148.jpghttp://forums.pelicanparts.com/uploa...1396843205.jpg
fanaudical 04-06-2014 09:11 PM
I would think a used distributor in better shape would be a better starting point.
I've never seen a distributor in that kind of shape; was this thing submerged for a period of time?
pete3799 04-06-2014 09:13 PM
Working on a flood vehicle?
I'd source a good used one.
Wew 04-06-2014 09:22 PM
Here's the crazy part. The car ran. I put 600 miles on it and I'm in the process of restoring. Just dropped the motor and am going through it. It looks awful. I sprayed it with some gunk and cleaner. I am surprised at the amount of corrosion that is in it.:eek:
I did bead blast the housing and that is looking pretty good.
http://forums.pelicanparts.com/uploa...1396844537.jpg
timmy2 04-06-2014 09:40 PM
Wow, that is nasty...
I would give the people at partsklasic a call and see if they can help. They do offer a rebuild service and may have the parts you need. Or find a good used one.
Wew 04-07-2014 10:23 AM
Off to Klassik to a rebuild. Not much of a core refund due to poor condition of dizzy. Oh well.
Stay tuned and thanks for the input.
Gary
