carrerarsr65
f.i. to carb conversion
cis to weber conversion what do I do with the the vacuum line that went to cis 79 911sc thanks for all the help
Old 04-16-2014, 04:20 PM
non-whiner
mreid's Avatar
Which one? If it's your power brake booster, hook it up. Post a picture.
"Too much is just enough."
Old 04-16-2014, 04:24 PM
RETIRED
Joe Bob's Avatar
Consider changing cams, 20/21 or 964 profile.
2012 ML350 3.0 Turbo Diesel
Old 04-16-2014, 05:24 PM
carrerarsr65
vac line
its the line that went the to the cis system it come from the back left side of engine bay mixed in with the fuel lines
Old 04-16-2014, 06:18 PM
That's the brake boaster line and there are a couple options. I just decided to go with a pump from metric mind instead of dealing with tapping manifolds and other issues. Lots of research on this topic says this is the quietest pump around. It's also Swiss made for whatever that's worth.
http://www.metricmind.com/category/ev-vacuum-pumps/
1982 911 Targa, 3.0L ROW with Webers
Old 04-16-2014, 06:19 PM
