Engine out 91 C2
My 1991 C2 Targa with 125k miles on it needs a repair requiring engine be dropped out. What else should be done/checked while engine is out? I have searched other posts, just want to be sure I am thinking of everything. Appreciate any help.
There is a little known federal law that states Lightweight flywheel kit must be done ...
Then the triangle seal and funky s]haped hose . Insulation pad and pad-keeper . Pas Pump seals should be looked at . If I think of more , I’ll add |
Valve adjustment, check spark plugs, ignition wires, and distributor cap.
- James 1975 3.6 RS 2015 F10 535i 2011 911 C2 |
