Tool sizes? Crossover? Any charts?
I just got an interesting e-mail from a friend. He mentioned that there are many sizes of tools where metric and SAE are the same. I guess we all now 19mm and 3/4" work this way. His question was if anyone has printed a chart listing this...if so, he'd be glad to buy a sticker he could place on a toolbox. So, is there such a chart or table? I replied that if there was, John or Warren would know about it...:)
There are sizes that are close...but not really the same becareful of using the SAE sizes on tightened nuts/bolts because they do have a very good chance of rounding the head/nut...usually on the metric its either a little under the same as the SAE or a little bigger than the SAE and vice versa...
I know I found out the hard way when I was younger :P. I know a few off the top of my head that I just used... 3/8...10mm 1/2...13mm 9/16...15mm etc... |
Paul,
There aren't really that many in common fastener sizes ... 1-7/16" = 36 mm ... oil lines 1-3/16" = 30 mm ... early axle nuts 13/16" = 21 mm ... Nothing made in SAE works as well as the Klein 21 mm spark plug wrench in early OEM tool kits!!! 3/4" = 19 mm Others that are close, but always are dependent on fastener AND wrench tolerances: 11/16" ~ 17 mm 9/16" ~ 14 mm 1/2" ~ 13 mm 7/16" ~ 11 mm ...<b> Highly Critical hydraulic fittings on brake lines where Precisely-fitting Flare-nut Wrenches are REQUIRED!!! DO NOT use loose-fitting flare-nut wrenches!</b> 5/16" ~ 8 mm |
It's just arithmetic, 1"=25.4mm...
use common sense, no 12pts w/ poor fits, etc... 1/32" = 0.79mm 1/16" = 1.59mm 3/32" = 2.38mm 1/8 " = 3.17mm 5/32" = 3.97mm 3/16" = 4.76mm 7/32" = 5.56mm 1/4 " = 6.35mm 9/32" = 7.14mm 5/16" = 7.94mm 11/32" = 8.73mm 3/8 " = 9.52mm 13/32" = 10.32mm 7/16" = 11.11mm 15/32" = 11.91mm 1/2 " = 12.70mm 17/32" = 13.49mm 9/16" = 14.29mm 19/32" = 15.08mm 5/8 " = 15.88mm 21/32" = 16.67mm 11/16" = 17.46mm 23/32" = 18.26mm 3/4 " = 19.05mm 25/32" = 19.84mm 13/16" = 20.64mm 27/32" = 21.43mm 7/8 " = 22.22mm 29/32" = 23.02mm 15/16" = 23.81mm 31/32" = 24.61mm 1 " = 25.40mm excuse the uncommon thirty-toooths, the one liner program didn't know any better |
I have a 25/32" socket...totally useless unless I'm near a 727!
| All times are GMT -8. The time now is 07:28 AM. |
