Gas tank Seal replacement
Can i replace the seal in front of the gas tank on my SC without disconnecting the fuel line underneat ?
Old 04-13-2014, 03:17 AM
Northern Motorhead
wildcat077's Avatar
The seal covers the whole bottom circumference of the gas tank so the only correct way to replace it is to remove the tank and scrape off the old seal and clean the area before installing the new one.
For what it's worth,i've removed my tank three times so far and i've used thick weatherstrip seals from the hardware store,i think they come in 20 ft rolls and cost around 10 dollars ...
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-13-2014, 07:10 AM
Just did this job, tank will have to come out. It's just to tight underneath to make it work. Don't be surprised if there is rust on the lip around the tank.
1982 911 Targa, 3.0L ROW with Webers
Old 04-13-2014, 08:59 AM
Doing this right now. Pull the tank. While you at it clean the screen at the bottom of the tank.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 04-13-2014, 09:26 AM
Northern Motorhead
wildcat077's Avatar
Forgot to mention the rust part ... i had to clean mine up a little as well !
Cheers
Phil
Cheers
Phil
Old 04-13-2014, 09:34 AM
Thank guys, the tank will be out in a couple of days - I'll hope!
Old 04-13-2014, 01:19 PM
Another good tip is to use a jack with a piece of wood to gently unseat the tank from the frame. Mine was pretty well stuck.
Old 04-13-2014, 01:50 PM
