COLB's Avatar
Leak down the valve cover
After perusing the grillion oil leak threads, I don't have a great answer.
After dropping my engine last month to fix the trinity, the oil cooler, and the cam lines, a new oil leak has emerged:
This oil is dripping down from the top of the driver's side lower valve cover, from the front (transmission side) of the engine. After driving, it drips about a quarter-sized amount.
The valve cover gaskets are new, with the silicon bead. The oil is running down the left edge of the valve cover from the top left corner (toward the from of the engine), but it is not clear if it is actually coming out of the top corner of the valve cover, or from somewhere else.
What is baffling is that there really isn't anything above the valve cover that could leak, is there?
I initially tightened the valve covers to 8 ft/lbs as recommended by Wayne's book. When I saw it was leaking, I re-torqued the driver's side cover to 18 ft/lbs as per Zimmerman's recommendation. But there is no change in the leak.
Could it be coming from the #3 cylinder? When I adjusted the valves the head studs were all good, as were the rocker seals.
I guess I can get another gasket kit, and redo the driver's side to see if that fixes it -- but I understand that is going to cause a huge mess unless I drain the oil first.
Does this look familiar? Any recommendations other than use a drip pan, and drive it until it needs its next oil change?
Thanks!
07 Boxster
88 Carrera Cabriolet 3.2 (sold)
05 Boxster S (sold)
Old 04-04-2014, 08:20 PM
pors1968's Avatar
I would recheck rear roker shaft.
Old 04-04-2014, 09:24 PM
COLB's Avatar
Thanks -- I guess this is possible, but they were are well seated when I checked the valves, and weren't removed or messed with.
Also, I would think the oil would be running straight down the cylinder cooling vanes rather than running down the outside of the valve cover.
I will pull the top valve cover to check the rocker shafts at the same time I replace the lower.
07 Boxster
05 Boxster S (sold)
Old 04-05-2014, 04:56 AM
kodioneill's Avatar
Check the top cover for warping. Check the intake rocker shafts.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-05-2014, 06:29 AM
Porsche-Poor
bcoats's Avatar
I have something similar and checked everything like you and have been told it is more than likely leaky cam tower seal(s). . .good luck and hope you find it
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 04-05-2014, 09:06 AM
I found a leaking banjo fitting once causing this, but I don't think there is one one the forward end of the intake cove on the driver side. Mine was in the rear and the fitting was somehow not tight enough. Took a couple of months to figure it out!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-05-2014, 10:16 AM
COLB's Avatar
It's leaking from the front (transmission side) of the engine, not from the cam tower.
I am hoping it is a rocker shaft worked loose. Will pull the upper valve cover this evening and check it out.
Thanks for all of the suggestions.
07 Boxster
05 Boxster S (sold)
Old 04-05-2014, 11:42 AM
COLB's Avatar
To close this out for posterity, I removed the upper valve cover, wiped it down, and re-torqued to 18 ft/lbs (from the original 8 I used). This seems to have stopped the leak.
I've heard folks say that the uppers don't leak -- well, I guess they will at 8 ft/lbs!
07 Boxster
05 Boxster S (sold)
Old 04-12-2014, 06:07 PM
