Anachronistic Anomaly
lfot's Avatar
What adhesive for rear bumper seal?
I've found a few different adhesives here on PelicanParts, but I'm not sure which would be best for the rear bumper seal that goes underneath the reflector on impact bumper cars. I realize it's a high temp area.
Suggestions?
Derek has a couple old Porsches and writes music for a living.
IG@ the_derek_whitacre
Old 04-13-2014, 04:53 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It isn't, it is held down by the bolts and a screw behind the decorative rubber button into the bumper then the tip is held in place by the bumperettes, if you need to work on the bumper or impact struts, it will be a mess to remove the adhesive.
'85 Carrera Targa
PCA/POC
Old 04-13-2014, 05:12 PM
lfot's Avatar
Other threads spoke of an adhesive that attaches it to the car, not the bumper.
Old 04-13-2014, 05:17 PM
DRACO A5OG's Avatar
Really, strange, it really does not need it. I guess if you removed the bumperettes, then you need something to hold the end onto the bumper? Strange
'85 Carrera Targa
PCA/POC
Old 04-13-2014, 05:21 PM
You're referring to the seal that goes between the horizontal topside of the bumper and the bottom of the rear Porsche reflector, yes?
If you buy a new replacement seal, it's got a peel-and-stick adhesive attached which sticks to the body trim underneath the reflector panel. For the curved sections that wrap around underneath the tail light clusters, I just used some quick dry crazy glue. Just finished this a couple weeks ago, but holding up well so far.
1988 JDM Carrera 3.2, cat delete, Fabspeed exhaust, Euromeister replicas (Fuchs in the garage). LOVE IT!
Old 04-13-2014, 05:29 PM
DRACO A5OG's Avatar
Oh snap nevermind, just got eye surgery, ignore pleaseeeee
'85 Carrera Targa
PCA/POC
Old 04-13-2014, 05:31 PM
lfot's Avatar
Did you use the seal that's for sale here on Pelican?
Old 04-13-2014, 06:47 PM
Cooper911SC's Avatar
If you are re-using a seal, or the new seal comes without adhesive pre applied, I would use 3M Black Super Weatherstip adhesive.
Apply to both surfaces and let it flash off before you press the two surfaces together.
Should be fine once bonded and sandwiched between bumper and rear apron.
Cooper
Old 04-13-2014, 08:50 PM
lfot's Avatar
Thanks, Cooper.
Old 04-13-2014, 09:17 PM
1984 Porsche Carrera
ozracer's Avatar
Im replacing this piece at the moment but mine looks too long it looks like it is supposed to finish in the groove at the bottom of the tail light housing recess mines a little longer than that can you show me a pic of yours in place to see if Im doing it wrong?. Its the same length on both sides and is a genuine part so Im a little confused.
Old 04-14-2014, 12:36 AM
