wolds's Avatar
Oil Analysis from Blackstone Labs
Thought I'd post the results of oil analysis of my 83 SC. Was pleased with Blackstones service and that the results were good and will shoot for 6K on the oil this year. Warren
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-08-2014, 05:01 PM
Porsche fanatic
jager911's Avatar
Nice results with Brad Penn, what was the cost? Did you sample hot or cold? I did a couple of tests years ago and used Titan Labs.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 01-08-2014, 07:19 PM
Cars and Cappuccino
tdw28210's Avatar
BP's Zinc looks to be well within claimed levels.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 01-08-2014, 07:36 PM
wolds's Avatar
The cost was $25.00 plus the shipping to Fort Wayne which was another couple of bucks. I took a hot sample from the car. Pulled the plug on the tank and let it run for a few seconds. Just long enough to put the plug down and pick the sample container up. Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-09-2014, 03:01 AM
run it out to 10K and sample again.
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 01-09-2014, 04:51 AM
wolds's Avatar
I could do that, but I don't think I'll drive it 10K this year although I'd like to. I'm in the camp that changes oil at the end of the season so whatever I drive for the year that's it, so last year I put 4452 on the car, I was shooting for 5K. Any thoughts on Blackstones comment regarding the silicon content? Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-09-2014, 05:13 AM
cycling has-been
bkreigsr's Avatar
I use B-P in all 3 P-cars and the silicon has never come back higher than 11 (on my 3.2L.) It usually runs 6-9. (also from Blackstone).
Something else is going on in you motor. Have you used any gas or oil additives? (btw 10,000 miles on an change for your motor should not be an option - stick with once a year, or 3,000 - just for peace of mind.
If you are interested in a longer change interval, spend the $10 for a TBN analysis.
Bill K
Old 01-09-2014, 06:00 AM
wolds's Avatar
I had used seafoam in it starting in August of 2012 through Spring of last year because the PO hadn't driven the car much, but hadn't used it since. Blackstone didn't think much of it as you can see from the comments they made. Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-09-2014, 06:06 AM
porsher
aston@ultrasw.c's Avatar
thanks for posting
i had no idea the data was so comprehensive
i might just try it
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-09-2014, 06:48 AM
cycling has-been
bkreigsr's Avatar
The rosy comments are fine, but aren't the cylinders on your motor Nikasil?
..."Nikasil is short for NIckel Silicon Carbide. Silicon carbide is a very hard ceramic (much harder than steel) that can be dissolved in nickel. The nickel solution can then be electroplated onto the aluminum cylinder bore. The piston rings will then rub off the exposed nickel, leaving a very hard layer of silicone carbide to protect the aluminum piston from direct contact with the aluminum cylinder. With this setup, the engine tolerances can be much tighter for better performance. The cylinder must be re-plated after it is re-bored, but Nikasil is extremely durable, so the cylinder does not need to be reworked as often as an iron or chrome cylinder.[3]..."
Old 01-09-2014, 07:22 AM
Uncertifiable!!!
Uwon's Avatar
Warren,
Here is my Blackstone report on my 3.4 Turbo which I unfortunately crashed in 2009. Engine had over 250,000 miles with a top end refurbishing at about 205,000 miles. The samples were always taken after a DE weekend. As you can see I drove the car quite a bit given that it was in hibernation for almost four months a year. I have always used Valvoline VR-1 20W50. I always try to stay at or below 5,000 miles between oil changes despite recommendations to the contrary.
Your sample pretty well matches my four samples except for the silicon, molybdenum and boron. I have no idea what your high molybdenum and boron samples mean. A Google search may answer this. Your silicon reading appears high and bkreigsr makes a good point about the nicasil possibilities. Was any work done recently on the motor, such as fixing an oil leak or adjusting the valves? I have been told new gaskets, assembly lubricants and sealers often result on higher silicon readings. The reading could be affected by something as simple as using some silicon based lubricant on the rubber gasket when installing a new oil filter (yes, I have seen this!).
Our Audi showed up with a high silicon reading at 40K at 21ppm and the went back down again to single digit. Don't know why.
If I were you, I would keep on driving, change the oil at 5k or annually and sample your oil immediately after a long run. Please, do keep us posted.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-10-2014, 06:50 AM
wolds's Avatar
I set the valves last winter along with replacing the oil return tubes. Used silicone paste on the o-rings, but set the valve covers dry. I'm guessing if I had cylinder issues my fuel contamination would look higher. Car runs as it should with very good gas mileage numbers. Warren
Old 01-10-2014, 10:33 AM
tig tig is offline
Decode it.
tig's Avatar
Just got the report back from Blackstone. '88 coupe with 37K miles. Drove 960 miles over 11 months on this oil (Brad Penn 20W/50).
CHARLIE: This first sample from your late 80's Porsche looks pretty good next to universal averages. They
show typical wear for this type of Porsche engine after about 3,300 miles on the oil. You didn't keep this fill
in use that long, which is why wear metals read much lower than average. Still, they were in good
proportion, so we doubt any serious issues are in the works. The viscosity was on the mark for a 20W/50
grade oil and no measurable fuel or water contamination was found. Insolubles read low at 0.2%, so the oil
filter did a good job. Check back for trends.
It's pretty clear that the oil, even after only going 960 (almost all 'hot') miles for a year, is still near perfect. "Everyone" says for cars not driven a lot you should change the oil every 6 months. This is what I've done in the past. Now I'm going to feel fine only doing it about once a year.
'88 Porsche 911 Coupe - Venetian Blau ║ '78 Mustard FJ40 "Uglina" ║ '87 BMW 529i "Maytag" ║ '87 BMW 535is "Vlad" ║ '85 BMW 528i S54 "Minerva"
Old 03-18-2014, 05:17 PM
Banned
Not quite everyone - I've always considered most oil change interval suggestions, given on this forum and elsewhere, to be pure BS based on fantasy (such as the nonsense, 3K mileage standard).
Old 03-18-2014, 07:05 PM
My data agree with you.
'90C4
Old 03-18-2014, 09:02 PM
dshepp806's Avatar
During my shakedown (in the early days),....I learned one thing: be sure to get TWO (2) bottles of the extracted oil. I'd suggest you send the sample to Stavely's Lab for comparison within the "apples-to-apples" approach (if you will).
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-20-2014, 09:20 PM
weekend wOrrier
The geek in me couldn't resist! Since my car was new to me I just wanted to see what it looked like. I had a good feeling about the engine and skipped a PPI/leakdown test, so I was happy with this and thought I'd share.
Old 04-14-2014, 02:20 PM
Uncertifiable!!!
Uwon's Avatar
Look at post #11. Magnesium is consistently 8 or under whereas the samples from all other postings read 499 or over. Any idea of its significance?
Old 04-15-2014, 04:55 AM
Post 11 used a different brand of oil. Magnesium is an additive.
Old 04-15-2014, 05:09 AM
