Transaxle rebuilding question
Hi!
On my last stage putting my 911T 2.0 1969 back together I run into a question regarding my transaxles. In the overview picture one can see the extra spring washer (bottom middle (green arrow) This ring was in the assembly as I took it apart many years ago. In the second picture one can see the markings from where is was mounted in the assembly (red arrows). It is a 901 dog leg transmission with transaxles from ’69. All the exploded views I saw there was no (spring) washer……. Anyone any idea? (hope so ;-) Regards, Bart http://forums.pelicanparts.com/uploa...1397477782.jpg http://forums.pelicanparts.com/uploa...1397477799.jpg |
Those look like the spring washers that go on the shaft first (cup side towards the CV) but I don't know what would have caused that wear pattern as that's the side of the washer that would be against the CV.
Hi Pete,
Thanks for quick reply! Do you got/know exploded view!? So washer will spring load cv, must be difficult to add 'lock ring' any advice? Cheers, Bart |
Yes. You may need to push down hard to get the circlip ("lock ring") in. Before you start, use a brass brush to remove all crud in the grooves and slot. Test slide the CV joint and be sure it moves fully onto the axle. Put the C cup on, then put the circlip on with flat edges towards the CV (look closely and note the way the circlip was stamped - one side/edge sharp, the other not).
Hey guys,
As a Dutchie I maybe misinterpreted the answers.... Maybe this helps clarify. [1] axle [2a] spring washer (spherical/convex side down) (that will also explain wear patterns on spring washer side touching CV) [2b] spring washer (spherical/convex side up) [3] CV [4] circlip So the order to mount is: 1-2a-3-4 Does everyone agree on that? Thanks again, Bart |
| All times are GMT -8. The time now is 01:57 PM. |
