1-6-2-4-3-5-1-6-2-4-3-...
SSI exhaust
![]() This is my exhaust system. It's the stock exchangers and silencer (as far as I can tell) for a carb setup on a 1970 2.2E. While I don't have any technical issues, both the exhaust and the silencer look really bad (compared to the rest of the car) and perhaps towards the end of their life. I'm looking at what options I have to make things better, an upgrade to an SSI not being out of the question. Is there some way I can fix things up so they look better? Will there be any practical difference (performance, sound) if I go to SSI? Is the Dansk silencer close enough to the stock one I have?
'70 911E Coupe, Webers 40IDA |
I would rather be driving
SSIs are a copy of your current factory setup. You would not see any improvement switching systems.
If you do not like the appearance I would have them bead blasted and ceramic coated. This would likely be lighter on your wallet too!
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
What jack stands are those? Do you like them?
Who, What, When, Where, Why and How. |
Vintage Owner
Heat exchangers
Take a careful assessment on the state of the envelopes on your heat exchangers. If they are solid, I'd also recommend having them sandblasted and ceramic coated. I did that to a used set of 914-6 heat exchangers years ago, and they're still holding up beautifully. However, I always carry a carbon monoxide detector in my car as they are old and it's best to be safe. Check with the companies ( I used Jet Hot Coatings for mine) for current pricing.
However, if they're marginal, the SSI units are works of art. Other than lightening your pocketbook, there's no downside to them whatsoever.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
In maintenance phase
I just installed a set of the "new" SSIs made in Denmark. I noticed that it's a bit quieter (I think due to thicker tubing) and fit great.
My only complaints about the install were: 1. They come with a special tool instead of one of the holes in the originals - that isn't a big deal, but the tool is an oddball size. It isn't an M13 like it should be. Because of that the tool is useless. It will require some creativity to get that one nut on. 2. The heater tube connections are just a tiny bit larger than the originals - I couldn't get OEM paper coated foil heater duct to go over the heat exchanger side no matter what I did. Eventually I gave up and got some aircraft style hose - it fits, but I prefered the OEM stuff. I'm happy with mine. I understand that they add to the value of the car pretty much at a dollar for dollar rate, which is nice, but mostly I love no longer worrying about rust in my exhaust system. OEM steel that's been properly preserved should be of equal quality and longevity. I would have gone that route if my originals weren't already rusted all the way through and repaired once. Good luck!
1969 911T (Getting a 72E heart transplant) 2004 Volvo XC70 Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s. Last edited by daniel911T; 04-15-2014 at 12:27 PM.. |
I have a very old set of stock heat exchangers, I just keep patching them up by welding crack and brackets, and putting on patches. I use a mig welder and it is a great way to maintain these things,
I have a Bursch muffler and occasionally I take it off and paint it. I would love to put on SSIs, but am worried about frozen studs and big problems getting the old stuff off.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
unless you have no obvious damage to them or a real personal urge to adress them, I'd not touch them, because unbolting them often results in the PITA of broken studs.
for optical retouch you can semi-drop the engine, crawl under it, wirebrusch it best you can and paintbrusch them with some silver heat resistant paint. but yes, fresh stainless steel SSIs with a Dansk sports muffler looks and sounds awesome!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
93nav: the jack stands are by a tool company called Draper. I'm quite happy with them and most other tools I've bought from them. I think it's a UK company.
Even SSIs look ugly after a while.
Exhausts are such a PITA I would leave it as long as possible.
Pope,
I just noticed that you are in Romania, I don't think I will find many Draper products this side of the pond. How are things in Romania? Very many Porsches around? Especially early ones? Just wondering. Thanks
