Did anyone try these foldable ramps?
Found these are a local store and on the surface they seem like a good solution vs the old jacks - has anyone tried anything similar? Looking for a solution for getting under the car for small jobs
![]() Info here: Foldable ramps 2 in 1 160/200cm 500kg 1600kg 2x | Carpoint
'09 997 GT2 '86 911 3.2 '83 911 SC (work-in-progress) |
After many unsuccessful attempts with various products, I gave up on using ramps to get under my cars. That is, however, until a friend put me on to the wonderful two-piece 67" RaceRamps. They are great. They don't slip ever when you drive up on them, and when you remove the actual ramp part you can slide under the car from any angle. They are light, they store easily and they are quite portable. I'd never use any other ramp but these.
Two-Piece Race Ramps XT - 10 inch Lift Car Ramps
Joe Rose |
NB Fully extended capacity is 500kg for trailers only. I would check the car front / rear valance won't foul the ramp when driving on.
I use race ramps flatstoppers for when I store my cars - they're very good. Perhaps I should look into ordering the race ramps
