Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
howard freeman's Avatar
Common for those plastic bullet connectors to fall apart. On that 81 model, I have seen a high failure due to age of the O2 sensor control unit relay. It is under the passenger seat next to the control unit. A way to quick check the relay is remove the air filter & with the ignition on push up slightly on the air flow meter you should hear the frequency start to make a buzzing sound. If no buzz is heard , start troubleshooting at that relay.
Howard
P.S. push up just enough to start the freq valve,not enough to start the injectors & flood the engine & only for a second.
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe
03 X/5 3.0. 292,016 miles now Sons daily driver
08 X5 4.8 123,615 miles
Old 05-05-2014, 03:12 PM
Tags
911 sc , csi , power loss
