toddadale's Avatar
Power seat 89 3.2 one working, one not
For a few months, been dealing with blown fuse #1 for power windows - though I thought I solved it- replaced the window relay. No issues for months then was hit with blow fuse - blown just by turning ignition on - not even moving the window switch. Took the car to mechanic, they solved the window (fuse) issue.
Now, both "two power switches on the driver's side" it's a 4-way -had been working before I took the car in, now only the front vertical/longitudinal control works, not the recline rear one. They both worked before I too it to the shop. Any Ideas?
Question: do both switches work off the same power supply? I do not see how this could be a switch issue since both worked before service?
Any input my Pelicans?
If everything seems under control, you're just not going fast enough.
Mario Andretti
Old 04-18-2014, 07:29 PM
abit off center
cgarr's Avatar
It's common to have the wires fail where they exit the seat back. I had one I had to fix and noticed the passenger side was taped up when I recovered the seats.
______________________
Craig
G2Performance
Old 04-18-2014, 07:48 PM
toddadale's Avatar
So the best way is to pull the seat? Not fun done it before.
Mario Andretti
Old 04-18-2014, 07:50 PM
abit off center
cgarr's Avatar
They exit on the outside back you can pull on the wire and see if it looks damaged or you can just unplug that wire and hit it with 12 volts and see if the motor runs.
Craig
G2Performance
Old 04-18-2014, 07:55 PM
toddadale's Avatar
So that rear wire ( in the back of the rear driver's seat is power to the rear motor? Your very helpful - could I call you? just to save me a lot of time with some questions? I am in Portland...
Mario Andretti
Old 04-18-2014, 07:58 PM
