bcheney's Avatar
Clutch Disc option 89 Carrera: Power Friction Clutch Disc By EPS
Has anyone installed a Power Friction Clutch Disc By EPS 5312 into their 87-89 Carrera? Would like to hear some feedback on this disc. The Sachs disc is over $400 and this one is about $200. Just want to make sure this is a quality piece. I found this description of the disc on the web...
Some Porsche Automobiles were equipped, from factory, with a Sachs Rubber Center Clutch Disc. Over time the rubber in these discs would become dry and brittle and ultimately fail. EPS has come up with a solution. Fabricated to precise specifications, they have developed a superior alternative to the, failure prone, rubber center disc. Utilizing a steel inner plate for strength and longevity they implement the use of six dual springs for a robust yet supple recoil. They then went a step further and, with the help from Ferodo (the industry leader in friction material), developed a friction compound "Dynamex" that would far surpass industry standards. Furthermore, the "Power Friction" Discs have an astounding 29% more useable friction material. What does all of this mean? A Dramatic increase in clutch life without compromising comfort, pedal feel or performance.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 04-17-2014, 07:51 PM
Roger 911's Avatar
I just put one in my 915. Clutch slips under full throttle at 5K. Cant say if its the EPS disc for sure. But when I installed a Sachs disc last year, with all the same components, no slip. More info here.
New clutch slipping under full throttle?
Roger
'72 911 3.2
'18 Mustang Eco PP
'17 Mustang GT Conv
Old 04-17-2014, 09:26 PM
Northern Motorhead
wildcat077's Avatar
Stick with the proven Sachs units ... my rubber centered OEM disc exploded three years ago and i replaced with a Sachs spring centered disc.Car is close to 300HP 3.6 equipped and sees
approx 15 track days per season,no issues so far !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-18-2014, 04:29 AM
