72 T, prep for MFI adj
I,ve read, and downloaded everything I can find on MFI.
I understand the ten demadments, I think! couple of questions. Thermostat on pump, car hot - pin should be pushing on cam. What should I expect when car cools? contact or clearance? Car is cooling at present. I of course have the upper and lower hoses in place. I have not seen a diag showing all the hoses as I think I may have one missing. On the exhaust upper side approx below cylinder 3. It looks like a connection for a hose about 3cm. Thanks Jeff 911T |
