I have a 911 Control pressure regulator/Warm up regulator and wondered what line goes where?Part numbers on the side 035133403D and on top(cast) 0438140(094stamped after). This one has two vaccum/pressure lines in what seems like a 3 level regulator.Small line on the bottom,bigger line in the middle level and the regular lines on the top with the electrical connections and a white covered knob. Can you gurus help?
Marc.http://www.carchive.com/minstone/
2275T MS EFI '65 VW Panelvan http://www.vvwc.ca/minstone/ Last edited by panel; 09-15-2002 at 02:33 PM.. |
I think it might be an Audi # after doing some research.
2275T MS EFI '65 VW Panelvan http://www.vvwc.ca/minstone/ |
