missed a gear and floored.7000rpm spike safe for 3.2?
So i was accelerating on a pretty steep uphill and when i red lined on 1st gear i tried to change to 2nd but somehow failed.I thought that the gear was in so i floored on neutral.The revīs went to 7000 for like 0.5 secs and came instantly down when i let of the gas.It really didnīt sound too bad so could it even be tachometer lag?Does this damage anything?The car sounds allright.I donīt hear any weird sounds from the engine and there is no power loss.At the time of the accident the car had just been on a full engine maintenance and the engine was in the best operating temperature + the car is driven only 60k miles.I just need some calming words.Thanks.
gearhead
Probably fine. Wasn't under load. Not like a 5th to 2nd shift at 90mph.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Fleabit peanut monkey
An only 7,000 rpm blip was probably the result of a rev limiter. It was "told" to hit 9,500 rpm, if you know what I mean - And would have, if it could have.
Sleep well. My old MSD box has a 6500 RPM kill pill in it. It's really noticeable when it kicks in, but I am in gear. You were trying really hard to scatter the motor, unintentionally, and you were saved by engineers that know we have limitations.
1981 911SC Targa |
Yep, rev limiter. I hit mine at every autocross. As long as you didn't do what Matt said, you're fine.
Chris '75 911s 3.2 - Ice Green Metallic 87 951, '05 987 S '21 Jeep Gladiator 18 Tesla ModelX 100D, 20 Model 3 |
Did that in an 85 300ZX. I swear it sounded like shattering glass. Little tiny punching arms poking holes through the block. Odd shaped partial piston lumps in the belly of the remains of the block.
My 4 year old thought it was pretty damned cool getting a ride home in the tow truck. Thankfully, used Z motors can show up on your driveway for $500 from the bone yard. Coulda been worse.
1981 911SC Targa |
The stock RPM limiter in a 3.2 is at 6250 rpm, tell me about why yours would go higher and maybe i would be concerned.
I donīt know why it went so high.When accelerating normally it cuts the ignition at around 6300rpm as it is supposed to do.I am thinking it could also be somekind of a tachometer lag or something.I accelerated to about 6000 on 1st,clutch down -> changed to second gear (neutral in this case accidentally)-> floored -> tacho needle goes to 7000,i let of the gas and it drops instantly.Then i yelled swear words and changed to second and floored,wasnīt too concerned about it at the time but decided to ask from the forums just to be sure...
Did you hear it hit the limiter?
I hear/see it to hit the limiter at normal accelerations.But in this case i tried to change to second from a fast acceleration and changed to neutral accidentally,then floored the gas pedal and i think the ignition was instantly cut off but after the tachometer needle went to 7000.The situation was so fast that could it just been a loose tacho needle or something?Im new to the 3.2,actually drove it first time yesterday but couldnīt resist to test it to the limits...
Amazing how quickly these little buggers will spin. ![]() Very lucky, no damage to engine or sheet metal. Maybe a little to my ego.
94 turbo 3.6 74 carrera RS race car 05 denali XL "We are here to laugh at the odds and live our lives so well that Death will tremble to take us." Charles Bukowski |
Under free revving throttle without load, it may act a little differently. Spinning up to 7k on the tach may be normal. Hell, it may have died at 6,300 and then spun up from momentum of the needle. Sleep well, John. Here's a tip. Move the transmission lever to where it is evident the gears are engaged. Then lift foot off the clutch.
1981 911SC Targa |
I have taken mine under load to 7000 and plenty of times to 6800.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Brew Master
What they all said about rev limiter. My dear brother while we were out for a drive asked "is it okay if I get on it?" I told him "I insist" moments later I said "are you going to shift or just keep hitting the rev limiter?" Apparently his SC doesn't pull to red line quite as fast as my 3.2. He's fixing that problem now with his 3.2 rebuild to replace his 3.0
Rev limiter makes a funny popping sound I've hit it twice, one myself and once with my brother. BTW, ya gotta finesse these into 2 at higher RPM's or at least I do mine and so does my brother. Last edited by cabmandone; 04-17-2014 at 04:47 PM.. |
Diss Member
You are ok. Not a great idea in a 3.2 unless you upgraded the rod bolts. The factory rod bolts are stretch to torque and they are really pushing their limit at the rev limiter. When you get to an RPM where the cheesy stretch bolts can't take it you won't see a failure. What it will do is add a bit of stretch to the bolts reducing the clamp load and once the big end starts getting a little monkey motion at high rpms it will continue to degrade until it spins a bearing weeks, months, or years later. Get some Raceware or ARP bolts in there so it has something that was designed to take the load.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Tony
Did they upgrade the rod bolts on the club sport, which had a 6800 redline from the factory? I have never seen that they have ... if so, how did they get by with 9mm rod bolts?
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
Reiver
[QUOTE=cabmando;8020648]What they all said about rev limiter. My dear brother while we were out for a drive asked "is it okay if I get on it?" I told him "I insist" moments later I said "are you going to shift or just keep hitting the rev limiter?" Apparently his SC doesn't pull to red line quite as fast as my 3.2. He's fixing that problem now with his 3.2 rebuild to replace his 3.0
Tell him to get a 930-10 euro 3.0.....then his redline will be 6800-7000 and he won't have to worry about that low 3.2 redline. |
Brew Master
[QUOTE=Reiver;8020702]
Taking it apart is easy
In other words, this observation (for a very brief time) that the engine reached 7000 was an illusion.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
I take to 6800 almost every shift on track days, of which I've done ~8 a year the last 5 years. Its done about 20000 miles in this configuration. New rods are on the bucket list for this engine...I'd like to go 7500 rpm.
I drove the SC like this for about 30 seconds. I spoke to my mechanic and he said either it would blow up at the time, and if it didn't it would be just fine
![]() I was in 4th gear foot flat on the floor at about 120mph wondering why it wouldn't go faster, I thought I was in 5th. |
