Cabriolet trouble
Hey guys, got an 81 SC cabriolet, I usually drive with the top down but decided to change it up today, but for some reason my locks are about an inch away from falling into place? Is there an adjustment or something for this? Thanks
Old 04-19-2014, 01:02 PM
RETIRED
Joe Bob's Avatar
You should roll down the windows and check the alignment pins that go into the frame above the windscreen. Assuming manual not electric?
2012 ML350 3.0 Turbo Diesel
Old 04-19-2014, 01:45 PM
Yeah it's manual, pins go into the holes just seems like the locks are off or something
Old 04-19-2014, 02:18 PM
RETIRED
Joe Bob's Avatar
Something is binding in the frame.....lower it again.....if still short look to see if any of the bolts are loose.
Old 04-19-2014, 02:20 PM
Smoove1010
Smoove1010's Avatar
This may sound like a stupid question, but are the locks in the open position? If they are in the closed position and you try to push the front bar down, the locks will interfere. (I'm presuming the locks/latches are similar in principal to my '87...
Old 04-19-2014, 02:33 PM
83 911 Production Cab #10
JJ 911SC's Avatar
How long was is in the down position? I put mine up less than once a year, so sometime i need to really stretch it forward before drop it in.
Since this is conversion (cab started in 83) some of the answers may not apply to your fit.
Who Will Live... Will See
Old 04-19-2014, 05:36 PM
It was down for a while, what exactly do you mean when you say stretch it forward?
Old 04-19-2014, 06:05 PM
BE911SC's Avatar
Rear window unzipped? Is it cold out? Did they make Cabs in '81?
'84 Carrera Cabriolet
Old 04-19-2014, 07:07 PM
BE911SC's Avatar
HA! I'll bet that's it! (Ask me how I know.)
Old 04-19-2014, 07:09 PM
plumb4u2's Avatar
'83 was first year for the cab so this must be a targa conversion
Justin
84 Carrera Targa
98 F-150 4x4
Old 04-20-2014, 05:45 AM
JJ 911SC's Avatar
Pull it forward enough that the pin are centred and not rubbing going down the hole.
Old 04-20-2014, 03:33 PM
