SMOG fail on 86
Car failed the NO part of the test for 15mph.
Max is 804 for NO (PPM), and it measured 917. I did the usual, hard run and test. Car is in a good state of tune. No smoke on decel or start up. Burns about 1000 miles/1 quart. Any input is appreciated. Thanks -pegasus http://forums.pelicanparts.com/uploa...1398052987.jpg going to go for a second opinion in the am. |
Looks to be running a bit lean. Enriching the mixture might be enough to bring your NO down for a pass.
Cheers, Joe |
Thanks Joe. Will give that a try. I was thinking the cat
might be done. Guess I will find out. |
Keep your fingers crossed. |
| All times are GMT -8. The time now is 03:13 AM. |
