Polyurathane Sway bar Bushings Opinions
Going to do a Turbo Tie Rod Upgrade on the 84' Cab and thought I might as well
take care of a few other things while it is apart. I am interested in your opinions on Polyurethane vs stock rubber ones. Car is not tracked.
Old 04-22-2014, 06:30 PM
Location: behind the redwood curtain, (humboldt county) california
I think most would agree that poly is more firm. I have heard that poly yields less, hence the bars are more effective, (like going up one size).
Others will have to comment on durability compared to stock rubber.
I have poly in several cars and have not had "noise" issues, as is common in trailing arm or a arm bushings.
The cost difference should be minimal.
My .02, go for it.
chris
Old 04-22-2014, 07:06 PM
964TargaC2's Avatar
I have had them on my 964 for about a year, car feels a bit tighter cant say its because of the poly or replacing 24 year old bushings or a combination of the two) I also did the steering rack bushings in poly..
Make sure the area where bushing meets bar is very clean ( I polished mine lightly with emery cloth, use the grease sparingly, the more you put on the more dirt will build.
If they last more than 23 more years then they are better than stock
I think that maybe I'm dreaming..
Old 04-22-2014, 07:19 PM
Northern Motorhead
wildcat077's Avatar
I installed some on my 89 before i switched to Tarett swaybars,i got them on Ebay ... can't remember the seller but i received the wrong diameter ones and they quickly sent me another set and just said to keep the other ones.They were blue and made really well !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-22-2014, 08:18 PM
Northern Motorhead
wildcat077's Avatar
The Ebay seller for the polyurethane bushings is djia ... 100% feedback and excellent customer service.
No affiliation since i don't use their products anymore but i would highly recommend these guys for their quality parts !
Cheers
Phil
Cheers
Phil
Old 04-23-2014, 05:04 AM
