Horn intermittent
My 85 911 Targa's horn only works when it wants. Any ideas?
winter
The first thing to do is pull your horn pad and steering wheel to check wiring as well as the horn contact on the back of the steering wheel. The copper contact can become worn and may just need to be bent outwards to improve the contact with the ring on the back of your steering wheel.
Or the wire on the back of your horn pad could be loose causing intermittent functionality. This is any easy DIY to do, search for steering wheel removal threads. The wheel can come off quickly and unexpectedly when you are yanking on it, causing discomfort to your face. You have been warned! Good luck! |
1985 911 Targa- gone 2006 Boxster - gone 2000 Boxster - gone 2001 Boxster S - My baby... |
Same problem on my 73.5 was a bad ground of the horn itself. Sometimes wiggling the relay got it to work for a bit...
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
El Duderino
My SC has a horn relay. Easy and cheap to swap before you go digging in the wiring. The problem may still be the wiring but even if it's not the relay at least you have a spare.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
If you find out you have power, the horns are adjustable. There Is a screw to adjust them.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
El Duderino
It just hit me that if you check the relay and the horn contacts and they are fine, another thing to look at is the actual horns. I had a rock or something fly up and hit the horns in the front right wheel well. Old plastic coupled with debris cracked the horns and made them come loose. Also worth checking if you don't find the problem someplace else.
