Pittsburgh sand blasting
Has anyone used Ameritech (kevin) in bethel park to sand blast a 911 Porsche car body or similar?
b everything I read says do not do sand blasting unless the person is experienced and knows how to not stress metal.
1975 911S Targa Silver Anniversary Edition |
glass bead, walnut shells, baking soda, anything but sand.
thanks John
that seems to be the consensus.
anyone know of a company in the area that does not use sand?
Fleabit peanut monkey
JASCO and razor blades. Lowes.
Strip it in a weekend or less. ![]()
1981 911SC Targa |
did you do it in a garage or outdoors? I used stripper on wood in my house years ago and swore it off but.. things change..
The biggest reason is that many blasters aren't careful/willing to be patient.
They turn up the pressure and crank through the job. (Not surprising really)! The bummer is that doing this will warp the large panels like hoods and doors. It also work hardens the metal. This leads to the body man either needing to metal finish Or spread a skim coat of filler over the panels to get them straight again. Cooper |
