Coram Deo
Flapper box cable connection and cotter pin
All,
When pulling my flapper boxes to clean them up, the bolt that holds the cable to the flapper box vane snapped. Fortunately that was all that snapped. All the nuts came off smoothly, disassembly and powdercoating went swimmingly, and reassembly of the Unfortunately, I don't know the pieces or arrangement that attach the cable to the vane, since that was entirely oxidized. Can you help? The PET shows the bolt (16) coming up from the bottom, then a washer, the vane, a lock washer (presumably, it's called "lock ring B4") and a nut. Does the bolt really come up from the bottom? Between which two pieces does the cable go? The PET shows, and I have in my ziploc bag, a cotter pin (14). Where does that go? ![]() Here's someone else's flapper, worse than mine, which makes it appear the nut is on the bottom rather than the bolt (from Heater Flapper Box and Valve (73 911.)) ![]() Same with this one (from Heater flapper box) ![]() Oh- and has anyone seen number 20 (connecting piece)? I haven't.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
The cotter pin goes into the 'base' of the flapper to attach/hold one end of the spring.
Who, What, When, Where, Why and How. |
^^^^ correct on the cotter pin and yes the bolt comes up with the nut tightening down the cable
Coram Deo
Which means the cable runs on top of the vane?
No......cable runs below the vane as in your last picture.
The bolt has a hole in it that the cable passes through. A washer on each side of the cable and the nut.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Coram Deo
Pete,
The hole is probably 4-5mm from the head. If it goes bolt, cable, washer, vane, lockwasher, nut there's a lot of bolt (with a shoulder sized exactly for the hole in the vane) hanging down. The threaded part of the bolt has a smaller diameter than the shoulder and the hole in the vane. If the threaded part of the bolt passes through the vane, it seems like there would be lots of relative motion (i.e. slop, leading to loosening) between the cable and the vane). What am I misunderstanding? Dru
I think the nut snugs against the wire and leaves the upper part of the bolt to rotate in the vane. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Coram Deo
So here's what the bolt looks like.
![]() The shoulder is an obvious fit for the hole in the vane. Could it really be that it's not supposed to fit there? ![]() However, the way I fitted it up (from the bottom bolt, washer, vane, wire, washer, nut) was too tight. I'll try it again today with a better idea. Got one? ![]() Note that properly installed cotter pin in the background!
I'd have to say the parts diagram is wrong. Strange. Mine and one I worked on yesterday is like your second pic.
First off, I have only looked at a flapper after it had been removed from the car, you get what you pay for.
I think that RDM's second pic with the bolt shows the correct orientation for the bolt. What is missing is the two washers. The control cable goes between these two washers. Hopefully two pics of mine will show up below. I have not looked, does our host sell these bolts and washers? Thanks ![]()
I had my original washers so I didn't check on their availability, but the bolts were available.
They were identified as Clamping Screw M4x11, 911 (1965-89), and the PN is 901-211-683-00-OEM. Since the shank has a hole in it, do not over torque as they'll snap in two, or prepare yourself and buy extras.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Coram Deo
93Nav,
These pictures are extremely helpful. I know and understand exactly how it should go together and why. Thank you! Quote:
