Oxford_Hippo
Guest
Posts: n/a
Question 911sc: Metal hoops - for seat belts??
Hi,
seen long, metal loops in the rear footwell, behind where a rear passengers ankles would be.
they look about 7cm long, as though they are made for a seat belt webbing to be threaded through?
have also seen couple of SCs with this sort of metal hoop on the rear shelf - maybe for a racing harness?
Does anyone kow what these are for?
Old 09-18-2002, 04:16 PM
They are for luggage tie downs, not seat belts.
Old 09-18-2002, 04:23 PM
And they're available from VW supply houses - they're also used to hold VW bus door check straps.
Old 09-18-2002, 05:52 PM
Oxford_Hippo
Guest
Posts: n/a
thanks for the info.
the thing I find weird is that in the cars I've seen - they only have either the rear footwell loops, or the ones on the parcel shelf under the rear screen.
the hoops runs lenghtways with the back seats - so they'd be perfect for luggage on the folded down back seats if there were footwell AND parcel shelf mounts - but with only one or the other I can't see what use they'd be.
so I suppose my next question is - how are these hoops fixed down? welded?
thnx
Old 09-19-2002, 01:16 AM
