Hello, I was wondering if a Pop off valve could be helpful in the 930, or if it only nice for the sound!
And can it be mounted? ![]()
Viero,
You may want to try the 930 (turbo charging/super charging) board for a larger 930 oriented crowd. Both the 911 and 930 boards are filled with experts but are tailored to the different cars. Obviously there is overlap. I'm no expert but I've never known of a pop off valve on a 930. They typically are used on NA cars. Post it on the 930 board and you'll get some hits. Good luck! |
No pop off valve in the 930's different air box set up.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Did you mean blow off valve? Only mentioning this because of the sound reference.
Tom 79 911 SC |
