battery voltage or alternator issue
Hi Guys,
Here is the issue I have been having. I voltage on my car is fluctuating and I'm not sure why. When I take the car for a drive for 10 minutes or so the voltage is fine around 13.75 volts while running. Then I turn off the car and start it up again the runs at 12.00 volts. What's up with that? I have a brand new battery. What do you think is the issue? I'm using one of the devices that you plug into the lighter to get the readings. I got that tip from the previous research here :) Thanks! Ace |
When you restart it, rev it once to kick the alternator then measure the voltage at idle. The alternator only charges the battery when it needs it and in most cars will not start to charge until the rpms exceed around 1500.
After the restart, I start driving it and I get up to 4000k rpm or whatever and it is still only at 12 volts. Is that normal?
I can test the what you said and report back if that's different from what I said above. |
Where and how are you reading the voltage?
The Cap'n |
12.00 volts seems a bit low but if it always recovers to ~13.75 or above, then you have no worries. |
alternator to the battery (alt - starter - battery), an intermittent alternator, or an intermittent regulator. Also, the alternator light must always come 'on' with the key in the 'run' position and go 'out' once the engine starts. |
Battery charging voltage is rarely a function of RPM.... That, battery terminal voltage rising with engine RPM, only happens with a more fully discharged battery and/or a heavy electrical load, headlights, heater blower, etc, etc. |
How long, how far, must you drive before the battery voltage begins to climb, reaches 13.75 volts or more?
A good battery should put out just over 14V (13.8-14.1) range, from what I've seen on all my cars. If not then you may have an alternator going out, however please check all your grounds including the transmission ground. I found on my Carrera that my transmission ground was disconnected and my voltage was jumping around everywhere even with a new alternator.
When the car is turned off the batter should have about 12.5-12.6 Volts. If you battery functions as I mentioned above but when turned off it reads less than 12 or slight above but below 12.5 Volts then you may have a dead cell in the batter. I hope it helps, good luck. Best Regards, Determined |
Assuming you have a new battery (like you said in your OP) you might have an issue with your alternator.
Most likely the brushes are at the end of their life and sometimes it puts out power and sometimes it doesn't. As a result sometimes you see the voltage going to the 13V - 14V area (battery is charging) while at other times you are running off battery power only and you only read 12V. And as others suggested check the GND strap and the connections at the starter, the alternator and battery. Especially, if someone was in there recently. Ingo |
I just reread the thread. Testing your voltage through the lighter has got to be one of the WORST possible ways to assess the condition of the charging system. You MUST read the voltage directly at the battery posts, even if it means running wires into the cabin from the battery. The lighter is at the end of a lot of connections and wire of indeterminate condition, and will NOT accurately reflect charging or at rest voltage. It's kinda like the volt meter in a 914, commonly known as "eye candy". Do it right, do it once.
The Cap'n |
OK - Here's what I did this afternoon. I tested the voltage at the battery while the car was off and then compared it with the voltage on the cig lighter meter. They were off by about .1 volts. I also checked when the car was running with low revs and parked . Again, it was off by about .1 volts or so. So I think it is a good enough reading. Here are the readings for the test:
Car off: 12.00volts Started car, headlights on/off for about 2 seconds, revved to 2000rpm: 13.75 V Had the car idle for about 5 minutes, backed out of the garage then stopped: 12.00 V Then drove for 10 minutes and the voltage went to 13.75 v then dropped to 12V Then 2 ten minute trips with start and stop. The Voltage was mostly 11.5v then at one point it dropped to 8 to 9 volts and the battery light came on and then went off on the dash board. Then back up to about 10 or 11V. Then I parked it and scratched my head. What do you guys think? Thanks! Ace |
Bad alternator (brushes EOL)
I had the same issue and it was definitely my brushes... I have an extra voltage regulator with good brushes if you need one pm me... If you are really worried I would take your alternator to an auto electrical shop and have them test it.. If you pull your voltage regulator out and the brushes are worn down you may need to get the bearings turned.. My unfortunate alternator was in bad shaped and needed to be replaced... :( Here is my thread with my situation.
http://forums.pelicanparts.com/porsche-911-technical-forum/783013-condition-alternator.html |
Voltage
Had a similar issue; voltage would be fine while driving for a bit, 14.4V, then drop to 12V or so. It turned out to be a bad ground cable from the tranny to the chassis. The cable looked good and metered fine, but the new cable solved the problem. However this was after a new battery, alternator rebuild and testing the tons of other electrical testing $$$. I used the little volt meter plugged into the lighter too. Excellent test tool.
If you can reproduce the situation, use a set of jumper cables to simulate a new ground cable. Connect battery ground to the chassis and engine at different spots to see if it fixes the voltage. |
^ start there
Clean the grounds, one at the trans, another one actually on the alternator (this means you have to remove the alt) and check the one at the a battery. These are the big ones, many more but I would start there. That being said, it sure sounds like the alternator is tired..... |
I had some similar problems as the poster, and I ended up replacing the voltage regulator which solved the problem. |
Agree directly at the battery is best but measuring from the lighter socket is way more convenient when trying to run down an intermittent issue. One thing I did when I bought a small lighter socket volt meter was connect it and good DVM to the battery at the same time. This allowed me to compare measured/displayed voltages. In my case the readings at the lighter socket were consistently .3v lower than at the battery. I don't care whether it's in the wiring or the cheap meter. I just remember to apply a little mental math to the cheap meter's read out. -J
If you go the new regulator route (contains new brushes) look at the slip rings in the alternator. If there is about a 1/16th of an inch groove worn in them think about getting a new/rebuilt alternator. The rebuilt one I got had some wear in the slip rings but not near as much as the one I took out. I assume mine was the original with 78,000 miles on it.
OP, you stated "new Battery".
Check the terminals, I was going thru hell trying to figure out my charging system, found out after a new starter, new alternator, (both needed service in any case), new ground strap/terminal and new battery to no joy. I don't know why but I checked my positive side and BINGO it had a hairline fracture. I swapped it with only a new $4.00 terminal, no more issues. |
Thanks for the info. I'll keep checking.
The cigarette lighter voltmeter has worked very well for me, and has proven to be an adequate indicator of my charging.
Why not take the car down to the local auto electric shop? The experts will hook up their stuff and give you the results for FREE in about 5-10 minutes. |
So where is that transmission strap. I did a little hunting here and couldn't quite find it. I found the part in pelican parts, but don't know where it goes on the car.
Should be on passenger side bolted to the body at the back where the floor starts to curve u into the engine compartment near the transmission tunnel. Runs from there to one of the transmission to engine bolts.
Sent from my iPhone using Tapatalk |
Strap should bolt to body near transmission tunnel where the floor begins to curve up to the firewall on passenger side. Runs from there to a transmission to engine stud.
Nope. Right firewall, a stud just in front of- and above the transmission mount, to a stud through the transmission nose cover, lower right corner. Be sure the strap goes OVER the mount cross bar, so it doesn't hang down where it could conceivably catch on something.
The Cap'n |
I stand corrected, the right side of the firewall isn't on the passenger side on right hand drive cars....Sheesh!
Guess I should of said find the reverse switch it will be within 10 inches of it on the firewall... Should be in the top right area above the floor to firewall seam if you are looking up and have this view. http://img.tapatalk.com/d/14/05/01/ru2enynu.jpg Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 02:32 AM. |
