gear shift coupling
the gear shift coupling in my 911SC 1979 is shot. Ive brought a whole new unit which I will be fitting at the weekend. does anyone have a step by step instruction on how to do this. Im assuming its pretty straight forward but would like any advice I can get .
Thanks Neil |
You may be able to find what your looking for right here on this site. Go up to the top bar of this page and look around in the Tech Info area.
Have fun!
'85 RoW 911 Coupe '65 356 SC '72 BMW 2002Tii '10 Cayenne '20 Ram Longhorn |
The directions are here in the tech area, if they are not for replacing the coupler its self take a look at the directions for changing the bushings as they will have a step by step on removal and installation. For the good of the community please do not throw away your old coupler they can easily be rebuilt and are often in need by fellow members here. You can always post it for sale in the parts section and try to make some of your money back.
Regards Dave Sent from my Nexus 7 using Tapatalk
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
It pretty much boils down to:
1. Put car in first gear 2. Pull back carpet 3. Remove 4 screw access panel 4. Unclamp coupler from shift rod 5. Remove cone screw 6. Remove coupler 7. Install new coupler 8. Install new cone screw 9. Align shift rod with trans 10. Reclamp coupler 11. Replace panel/carpet Optional steps: -Replace outer coupler boot(easy) -Replace inner coupler boot(harder) Both are likely needed/cheap if your car is 35 years old.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
free shifter coupling without bushes
reference good of the community. If anyone needs my old coupling only the bushes are shot happy to give it to you. The thing will only sit in my tool box so if you know of anyone that needs one let me know
neilemm@gmail.com |
I've done this, and it isn't too hard at all. But there was one step I found in the workshop manuals that I had neglected to do. The result was improper or imprecise gear selections (like going into third when I wanted first). I don't remember off hand what the step was, but I think it was to move the shift lever all the way to the right (or left) as you connect the coupling. That way, the right teeth engage the right grooves, making gear selection very precise. It's worth doing a bit of research before doing it, that way you'll only have to do it once.
