-   -   911 SC Power Window Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/808799-911-sc-power-window-problem.html)
tirwin 04-30-2014 05:36 AM
For '81-83, relay #5 (from the front) is the power window relay. Part number is 911.615.109.01.
Try this.
- Pull fuse #21. It's the one closest to the back of the car. Do the windows still work? If so, someone has messed with the wiring.
-Put the fuse back in. Now put a piece of tape or mark the fuse that came out of #5 so you know which is which. Switch it with fuse #4. Try the power windows. Do they still work? They shouldn't.
XMarks 05-19-2022 09:31 PM
Hi, I have a 80 911 SC and my driver side window works but my passenger side don’t. I replaced window regulator and tested the window motor and it works. Any idea what might cause the problem? Does the 82 diagram the for the 80?
Thanks.
