74 915 Trans Main Shaft seal not tight fit
I'm in process of replacing the 915 transmission main shaft seal on my 74 Carrera #57 restoration project. This transmission does not have the removable guide tube.
The issue I have is that the Elring seal 99911332740 which measures 23x35x8mm is not a nice snug fit as I would expect, I can literally push the seal in by hand using my PVC pipe to drive it in square. I tried another brand 35mm seal and it is not a tight fit either, I tried a 36mm seal and it is too large. Is there a sealing product used to seal and/or cement the seal in position?
I have pushed the old seal into the transmission and removed it through the differential cover. There was also another one still lingering on the main shaft that I removed as well. As a note these should be removed and not left inside, they do disintegrate.
I appreciate any direction.
Old 05-18-2021, 06:02 PM
Do you have the serial number to decode the version of 915 ? I don't know if there are different seals but might help run down the issue.
Old 05-19-2021, 06:32 AM
gearhead
It’s a known issue. The best fix, as usual, is the most expensive one. Ship it to CMS for machine work.
Old 05-19-2021, 06:54 AM
kevingross's Avatar
I am familiar with using an SKF Speedi-Sleeve to help with a shaft issue, but perhaps one could be used here to help with the bore. Dunno, never tried it! As Matt recommends, CMS can help and they do great work.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 05-19-2021, 08:18 AM
