| Registered Join Date: Sep 2007
				New spring clutch disc on original alu pressure plate
			Hi, I know, that I have turned this topic about my clutch a few times, but I hope that you will be able to solve my last question  . I have the original clutch in my 71' 911T. But the clutch disc needs a replacement. The current clutch disk is the original rubber center clutch disk, see image below:  The rubber centered clutch disc looks way thicker than the newer spring centered discs, which is why my question is: Will the new spring clutch disk (SACHS 1878 005 614) fit the old pressure plate (SACHS 3032 015 199) ? Below is an image of the original alu pressure plate:   | ||
|  04-27-2015, 12:17 PM |
