Je Ne Sais Quoi = Targa
Setrab 72 row oil cooler in a 911 with RSR-type bumper
My '74 is almost finished with the 3.6 conversion, but regarding the 72 row Setrab oil cooler up front, the flat panel behind the cooler does not not look conducive to good air flow, anyone have any pics, experiences, tips, sneering or derision, heeh heeh, etc,
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018, '81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust, Had a '71 911S Targa in the 80's, miss it, Had a '61 Roadster in the 70's, miss it also, |
You can buy the rs style air deflector from elephant racing amongst others .
Northern Motorhead
I installed a fiberglass bumper from Patrick Motorsports when i did my 3.6 last year,regardless of what you may think about air flow it is plenty to keep the engine temps down.My car with the 3.6 and front bumper mounted cooler runs cooler than my 3.2 ever did !
Don't even worry about it ! Cheers Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
I had a DP motorsport front spoiler with an original RSR cooler on a 930. No cutout and it ran very cool.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Brown Out
Setrab 500 cooler behind RUF valence
Never a issue always runs very cool.
RR Wood 1960 Corvette 1980 911SC 3.6 1998 Chevrolet S10 Sportside LS1 |
Wer bremst verliert
It is not conducive to airflow, you are right. You might try it first though, I have the same setup in front with a lot more HP and I have no problems with heat. Slower air - to a point - is actually better at transferring heat off the cooler so you might find you are OK.
For the ultimate cooler airflow DIY check out Chuck (Elephant Racing)'s thread on the hood he cut and channeled to get flow through the front cooler. An extreme, and extremely cool solution.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I worried about the same thing, but it has not been an issue. When centered in my IROC front bumper opening (up and down), my cooler is just below the bodywork. Here are a couple of pictures (excuse my crude blacksmithing - I'm not an artist like the rest of you folks when it comes to fabricating stuff
...). FWIW, I modified a fender-mount cooler and put it in the front bumper. Even in 90 degree weather, my temps never exceed 180F (no track time since I've installed this, though).![]()
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Northern Motorhead
Mike,
What are you talking about crude blacksmithing ... lol ... that is a very nice looking installation ![]() Better than mine,i'll have to rethink mine next time i remove the bumper ! Cheers Phil
If you look at the install above, you can see there is enough open space behind the lower half of the cooler to get good flow. I bet the air flowing under the car helps to pull it through too.
