defective ox sensor connector
I m looking for the man who puts together a rebuild kit for the body side male connector where the plastic is failing or has failed.
I have researched different variations of my title but nothing shows up except likes of what I want to repair. Thanks Bruce |
Try Louie...
It is a great fix.
Mine was easy to fix with his part. |
+1. Worked great and he's a good guy to deal with. No more floppy connection.
Added a dab of loctite to the screw in wire connection for the green wire and slipped a short section of large diameter heat shrink tubing over the whole male side assembly and gently heated when I was done. Tacked it back onto the black metal holder bracket as intended. Looks factory. Tight connection. |
| All times are GMT -8. The time now is 10:46 AM. |
