What are the consequences of overfilling the oil?
I recently completed replacing all the oil return tubes on my '86 3.2. In retrospect, I probably should have drained all the oil beforehand but I didn't, as the car had an oil change not long before that.
The problem now is that I have no great idea how much oil is in the car. I'll take a wild guess that somewhere around 4 to 6 qts came out when I took out the old tubes. So at this point do I just drain the whole thing and waste whatever quite fresh, expensive synthetic oil is in there? Or, do I put 6qts in and run the risk of overfilling? I guess another way to ask this question is what's the minimum amount of oil in the car where it's safe to run the engine (since the car needs to be warm to really check the oil)?
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
id say put a couple quarts in and slowly fill as needed. you dont want to overfill it. it gets in the intake and gunks everything up
82 SC , 72 914 |
Thinking about it a little more, it would seem I lost most of what was in the crank case but the oil tank should have been unaffected. Does that make sense?
I believe the oil in the tank does get affected, but no idea by how much.
Another idea is to measure what you've drained. Otherwise if that is not possible, do you really want to risk reducing the life of the bearings?
"Simplicity is supreme excellence" - James Watt |
or you could just drain it into a clean container and pour it back in. that shouldnt be too difficult to keep it clean
82 SC , 72 914 |
Why can't you just fill it slowly until it registers on the dipstick. Then spin the motor (with fuel pump fuse removed so it doesn't fire) which will suck oil from the tank, then add a little more oil, start the car, make sure you have enough pressure, drive it until it gets to temp, and then fill until it above the first mark on the dipstick.
Formerly known as Syzygy
I think registering on the stick with the car cold and not running is over filled.
If you don't know how much you lost, then it's probably best to drain what you have into a clean container to measure, and then add that back in. If you think you're down only about two or three quarts, you can get away with running that until it's hot to check the oil. The system capacity is quite large, and even the difference between the lower and upper mark on the dipstick is 1.75 quarts.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Speed Dog's Chauffeur
Tank elevation vs. Air Box elevation
I had a 73 MFI car come into the shop where I worked as a teen with just 3 quarts in the sump. Motor was fine so be happy about your Porsche dry sump. Owner was used to US cars and said the alternator light was flashing(parking brake). Years later, I had a body shop overfill my 911 because the oil light flashed when the parking brake was up and made a mosquito killer until I drained the case of 3 quarts and cleaned the CIS air box. IME Yes, overfilling is very easy to do. Happy cleaning.
Porsche-Poor
If I remember correctly, I believe there is about 3 quarts in the sump, I think adding 2 to start should be safe and add when registers on the dip stick
1979 911 RS clone hotrod 1983 930 turbo-sold, will be missed 1992 964 C2 Coupe-regrettably sold 1980 911 SC Weissach-regrettably sold 1975 911S-sold but not forgotten |
It's very easy to stick a tube from a manual oil evacuator pump into the oil fill tube and suck out any excess oil. I did this on my Targa when I first discovered that it was overfilled by the previous owner. We use these type of manual pumps when changing oil in our boats because you can't get to the bottom of the engine to drain it. You simply stick the pump tube into the dipstick tube and pump out the hot oil. Amazon.com: Mityvac 7400 7.3 Liter Fluid Evacuator: Automotive
1976 911 Targa 2.7 CIS Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior 1963 356 SC- crashed ![]() 1962 356 C- sold ![]() 1965- 912- sold- fun but too slow |
Drain it all out & start over. Get rid of the low zinc synthetic oil & use either Valvoline VR1 ,Brad Penn, Joe Gibbs Driven DT40 or Motul 8100Xcess. Your cams will be very happy.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
FWIW, the oil is Mobil 1 15W-50, which is pretty close in zinc content to those you listed.
I personally would not use Mobil 1 in a 911 engine - ever. Second thing, and I think most people covered it, if it's overfilled (my experience) it gets in the intake, and not only that it sprays the whole engine compartment. The past owner of my car overfilled the engine every time, and it took days to clean the engine (not to mention the huge puddle of oil in the CIS intake that looked to have been there for years as it was pulled in and refilled with oil).
