Kartoffelkopf
Spenny_b's Avatar
Windscreen Washer Tank - Drain Plug - Help!
Hey guys,
This is doing my head in, so need to ask the collective to see what can be done.
A short while ago I was removing the washer tank from the LHS front arch so I could clean and refurb the area....decided to drain the tank first but the drain plug must've gone brittle over the years, and cracked whilst undoing --->
Have tried super-gluing it, barely got it finger tight before it sheared off again.
Thought I had a Eureka moment the other day; there's an item in the PET listing for the washer system (904-10) described as a "Plug", with a part number for an item that isn't in the illustration. Ordered it, in fact at 19p each I ordered two (!), but sure enough it isn't the correct part....it really is a plug, no use to me at all.
So, I had a look in the PET for the 993 and up to '89 G-Series model, and like the 964, they don't list the drain plug separately.
Does anyone know if this is a common part to a 924, 944, 968, 928...ANYTHING?....I really don't want to buy a whole new washer tank, to get a 50c part!
I know in the early 90's that a lot of Mercedes parts were used....anything doing with MB's?
Any help appreciated....currently preventing me finishing off the whole front end of the car.
Cheers
Spencer.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 11-13-2014, 02:51 PM
