Removing A Arms (Control Arms)
Hey All -
Trying to remove my A Arms from the car. I have everything disconnected - but am having trouble pulling them out of the bushing that is next to the rear of the torsion bar. Should I remove the torsion bar first? Any other tips? There are A LOT of threads where people are removing their bushings and the A Arms are already out of the car - but I can't quite get to that point. Thanks - Jonathan |
Pull the t bars and remove a arm with bushings attached you will not be able to put it out if the bushings.
Yup- just discovered that. For some reason, we thought the A Arm had to be pulled differently.
Removed the long bolt and pried out the A Arm. Now to heat up those Bushings and get them out. Rebel Racing going in! |
| All times are GMT -8. The time now is 01:27 AM. |
