JD-GT-350's Avatar
1987 steering wheel removal ?
Any guidance on the removal and installation of the original wheel?
Jim
Old 05-04-2014, 07:06 PM
HarryD's Avatar
A search will result in many threads on the topic.
You pry the horn pad off the wheel (the horn button method given is for an earlier wheel) and this article explains the rest: Pelican Technical Article: Steering Wheel Removal and Installation
You will need a 27 mm socket to remove the nut.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-04-2014, 07:50 PM
Dave Colangelo's Avatar
How To:
1) Pry Horn pad off
2) Disconnect wire from horn pad
3) Turn on air compressor and wait for it to fill
4) Use 27mm socket and impact wrench to get the nut off
5) Mark the wheel by drawing a line that is on both the wheel and the center spline, this will aid in installation
6) wiggle the wheel off.
and as they say, installation is the reverse of removal...
Regards
dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 05-04-2014, 08:07 PM
Did it under 5 minutes........
Originally Posted by Dave Colangelo View Post
How To:
1) Pry Horn pad off
Regards
dave
I was there when Dave did it under 5 minutes!!!!!! It took me longer to get the tools, run the compressor, and return the impact wrench and socket back to the tool box.
Tony
Old 05-04-2014, 08:18 PM
Pro tip: pull the horn relay first.
Dan
'86 Carrera coupe
Old 05-04-2014, 11:38 PM
froggert's Avatar
iirc don't fully remove the nut before pulling the steering wheel. leaving it on will allow it to act as a stop, preventing the wheel from smashing into your face if you yank too hard.
Old 05-05-2014, 09:03 AM
Also reinstall with appx 40lbs torque on the steering wheel nut.
Old 05-05-2014, 11:08 AM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
You shouldn't need an impact wrench, but a deep socket is a big help.
Old 05-05-2014, 01:36 PM
I am not sure you can pry it against anything. I just grasped it with two hands and pulled trying to limit the travel after it gave.
Another good idea is to torque it so you are puling on the wrench down into your lap instead of pushing it up toward the windshield.
Rick
88 Cab
Old 05-05-2014, 01:55 PM
My 87 steering wheel removal took a little more work than that. After removing the horn pad, there is a horizontal piece of steel( part of the wheel) which prevents the deep socket from finding the nut. I had to bend this piece out of the way in order to get the socket down to the nut, then bend it back when re tightened . Nothing the channel wrench can't handle.
Old 05-05-2014, 05:00 PM
Michael T's Avatar
Set the ignition to where the steering wheel frees up from the lock when it is off. This will save the lock mechanism in the steering wheel. I second the leaving on the nut a bit to keep the steering wheel from coming off into you or the windshield.
1987 928 S4 - Black
2014 C4s 991 - Agate Grey
2014 Cayenne - Mahogany metallic
Old 05-05-2014, 06:54 PM
kuba_kuba's Avatar
Either a wobble extension or universal joint extension for your socket will allow you to clear the sheetmetal on the later cars. Once I had the right tools, took <5 minutes to remove the steering wheel. Keeping the nut on after loosening is good advice.
'88 911 Targa
Old 05-05-2014, 07:01 PM
froggert's Avatar
i forgot, a deep socket wouldn't clear the piece of metal on mine, either. had to find a regular socket and use an extension to get at the nut.
Old 05-06-2014, 08:36 AM
Porsche Crest
Had the same problem on my 85, with the piece of metal.
13 Boxster
85 Targa-sold
99 Boxster-sold
88 Targa-sold
84 Cab-totaled
Old 05-06-2014, 08:53 AM
OsoMoore's Avatar
I took the opportunity to buy an electric impact wrench from HF. No risk of damaging the steering mechanism, and you'll love having it for removing the wheels.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 05-06-2014, 12:57 PM
