82 911SC Cabin Temperature Sensor?
Good evening, I am in the process of restoring my first 911 (1982 SC Targa). Don't mention anything about breaking off heat exchanger nuts...I have a question: My car is missing its Cabin temperature sensor which should be between the visors. Are these available anywhere or is there an alternative which would work? Thank you, Jeff
So that's what the hole with 2 smaller screw hole is for!
Jeff, Have you found a substitute for the heat sensor? I need one as well.
| All times are GMT -8. The time now is 10:22 AM. |
