-   -   LED Gauge Tutorial (http://forums.pelicanparts.com/porsche-911-technical-forum/809742-led-gauge-tutorial.html)
rokemester 11-15-2016 04:22 PM
Originally Posted by Oyagi (Post 9360589)
Thread bump!
Just updated all my tires oem bulbs with the leds and love them. However, I'm having a helluva time getting the rubber basket around the speedo sitting properly around the gauge when it's pushed back in. Short of cutting into my dash to widen the gauge "hole", any tips? Swapping the bulbs took no time, getting that tach back in and looking with the rubber gasket is turning into a pita.
John
Try coating the gasket with some Armoral or similar rubber conditioner. It may help. That's what I needed to do to get everything to snug up and align.
wildthing 11-15-2016 04:26 PM
Interior cleaner is what I used. Also don't leave them in an odd shape too long. They will stretch.
Oyagi 11-15-2016 08:00 PM
LED Gauge Tutorial
I ended up using foaming hand soap and got the gasket back in. What a pain. Now my interior smells like Bath and Body Works Beach Day scent ;)
garm 11-21-2016 08:02 PM
Great tutorial and exactly the way I did it. Here are mine:
http://forums.pelicanparts.com/uploa...1479787320.jpg
Jmeg8237 11-01-2020 10:30 AM
Just found this thread. Looking forward to doing this because I just got an '87 Targa and the gauge illumination at night really sucks. Thanks.
GAJon 11-01-2020 03:42 PM
Just adding my $0.02 to this thread. The positive connection on the bulb is a little wire with a small connector pushed through a PCB board. If tension on the positive wire is released, it's possible for the wire to bend to the left or right in the connector which will cause it to contact the side wall (ground). You'll end up with a bad short that will cause problems.
Just make sure that the positive wire is properly seated in the holder and that the bulb is properly seated when installed. Worth a double check to avoid issues..
sky1jord 11-01-2020 08:21 PM
I posted this sometime before, but i see the subject coming up again.
So, this tool, available wherever paint is sold
https://www.thepaintstore.com/Hyde-Tools-Paint-Can-Bottle-Openers-2-Pack-p/46445.htm?1=1&CartID=0
will help pull out your gauges lickety split, no brooms required. It's also helpful in opening paint cans.
Rubbing some dish or hand soapy water on the rubber gauge surrounds will allow you to slide everything back together real slick without tears or bends, and soap won't hurt the rubber.
Cheers
