-   -   Alternator warning light..... (http://forums.pelicanparts.com/porsche-911-technical-forum/80985-alternator-warning-light.html)
bill mateer 09-17-2002 05:14 AM
Hello all:
recently the alternator warning light on my 79SC stays lit for sometimes upto 10 secs on a cold startup, ie. only in the morning, after that all day it is OK, goes out right after start..
Iwill check the v-belt to make sure it is tensioned properly, but other than that what are some symptons for an alternator or voltage regulator getting ready to bite the dust ???
[or is this fairly normal on cold startup, now that it gets cooler at night]....
thanks for any help....
MBAtarga 09-17-2002 08:13 AM
I didn't have any alt warning light symptoms, but I did witness periodically:
- tach "bouncing" wildly
- headlights flickering from dim/bright/dim, moreso after engine was warmed up
Get a voltmeter reading - I used the cigarette lighter jack and witnessed voltage surges beyond 15V.
I had the alternator rebuilt and replaced the regulator to solve my problems (well, the problems above anyway.) I still have others :(
Sean Hamilton 09-17-2002 09:18 AM
Bill
Originally posted by bill mateer
......alternator warning light on my 79SC stays lit for sometimes upto 10 secs on a cold startup.........
Have got Wayne's 101 book - in there he explains several warning light symptoms and the diagnosis for each.
Jdub 09-17-2002 12:03 PM
You might try cleaning your ground at the battery. That's the cheap "fix." If that makes not difference, use the Search function to determine how to hook a voltmeter to the battery and load the car to check for voltage output.
Alternator AND Early_S_Man will get you great advice.
John
Ove 09-19-2002 03:15 PM
Bill,
Have a look at this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/79443-flickering-alternator-light.html
