Bearing specs for 71 911T
Does anyone have what the original specs were on rod and main bearing thickness on a 71 911T motor?
I am trying to figure out if I have a low mileage motor. I have a "field find" and the odo stopped at 12k. The car was complete. The motor would not rotate, but that was later found to be two cylinders that had rusted to the rings after sitting for about 19 years.
I split the case this weekend and the bearings look really good. I want to measure the thickness to see how much wear is actually on the bearings compared to new.
Thanks.
John
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 04-13-2015, 11:24 AM
