wheel spacer question
i want to put some wheel spacers on my 89 carrera and had 2 questions:
1) how does 10mm/20mm sound for FR/RR? 2) will i need the spacer only type (will there be enough thread?), spacer w/studs or spacers and replace my existing studs? |
Bye, Bye.
I just added 15 mm spacers. I prefer not running the adapter type spacer, so I swapped out the studs from 45 mm to 66 mm and added hub centric spacers. 66 mm studs should allow you to add up to a 21 mm spacer.
thanks scooter. did you do 15mm front and rear? how hard was it to swap the studs? did you need a press?
abit off center
I did studs on the car otherwise you have to remove the hubs just a big ass hammer. The rear longer studs as I remember only fit in one area so turn the hub till you find it. Then draw the new ones in with a spacer and nut.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Bye, Bye.
I only added a spacer to the rear. It was not particularly hard to do the rear, just took more time than anticipated....a couple of hours. Could be done faster, but I am slow and very careful.
Front would be more difficult.
Elvis has left the building. |
Rescuer of old cars
What size wheels? 20mm on the rear is pretty aggressive if you have 8" or 9" rears, but not enough for 7".
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
