Let's see your roll cages
Hey all,
I am considering adding a roll cage to my '78 911sc. I would like to see options which still allow use of the back seats for my kids? Is this possible without removing the whole cage? Pictures would be great. Thanks |
Are you talking full cage? Not a good idea on a street car. Not sure you can still use the rear seats with most any roll bar either. Here is my set up.
During install http://forums.pelicanparts.com/uploa...1399497339.jpg Crappy shot now. http://forums.pelicanparts.com/uploa...1399497389.jpg |
Full cage or half? Either way, use of the rear seats is out of the question. If you're OK with a 1/2, the DAS roll bar is bolt-in/removable.
https://www.dassport.com/store/categories.php?category=Truly-Bolt-In-Roll-Bars-%252d-No-Modifications |
I guess I mean roll-bar or half-cage. It is mostly to secure 4 point harness so I am learning a harness bar may be better for me?
I would never put a child's head in close proximity to a cage member, not safe. In an accident they could do serious damage to their precious heads. |
Whatever you do, it is imperative that the seat, harness, and roll bar are compatible or designed to work together. Seats should not be modified to accommodate a harness. Most harnesses are designed to be used with a race seat. The roll bar MUST be padded IF there is any chance of hitting it with any part of your body. |
Harness bar or preferably to me would be something like the Brey Krause harness truss...
Or going the 16k way via Ruf :)
Is RUF Integrated Roll Cage worth the cost? - Page 2 - Rennlist Discussion Forums Cheers, Thorsten |
Roll bar.
This is more of a street item from auto power. It has a removable cross bar.
I chrome plated it before intallation. http://forums.pelicanparts.com/uploa...1399671665.jpg |
| All times are GMT -8. The time now is 04:42 AM. |
