Washer fluid tank
Just spent whole weekend redoing my a/c system on my '83 SC.
The most difficult part was the removal and installation of the a/c hoses. Total time spent was about 8-10 hours and now I'm stuck at trying to bolt back the washer fluid tank in drivers side front wheel well. What's the trick to getting that damn tank back up so I can screw bolt and bottom strap? I spent 2 hours this morning and still can't get it back in. Mahalo, David
1983 911sc Ruby Red Metallic 1971 BMW 2800cs Chamoix 3.0csi/4sp 1956 VW Beetle oval 2000 Lexus GS300 fully built 2JZGTE 2008 Lexus IS350 F-sport |
I was able to get the screw in above where the filler hose enters the tank, first. I then worked on the strap, which took around 30 min of struggling. Fully loosened the screw to get it back/connected. Eventually got the strap hooked up, tightened, and then moved back to the first screw. Had to pull that screw back out, get the flange from second tank that sits above the washer tank lined up, then finally get the screw back installed. Overall, it was a major PITA. Hopefully someone has a better "process" than I just described as there has to be a better way!!!!
I took a break and asked my wife to look at it. She had it in there in less than 5 mins. Might want to get a fresh set of eyes on the problem.
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
