-   -   MSD SC rotor mod (http://forums.pelicanparts.com/porsche-911-technical-forum/810254-msd-sc-rotor-mod.html)
wolds 05-08-2014 09:17 AM
MSD SC rotor mod
All,
I've read all the threads on this subject and thought I'd take a stab at it. I have ordered two non-resistor rotors which I should have tomorrow, but on the outside chance they are of the resistor type and with idle time on my hands I though I'd take a used rotor and see what I could come up with. The plan is to vacate the rotor of its contactor, fill the void with JB weld till it's even with the projected tip and then fabricate a single piece of replacable brass to be held to the rotor body with a small machine screw. So this is the progress so far. Warren http://forums.pelicanparts.com/uploa...1399569322.jpg
http://forums.pelicanparts.com/uploa...1399569356.jpg
wwest 05-08-2014 09:28 AM
Why not just bypass the resistor? Or even use one of a higher wattage?
wolds 05-08-2014 09:35 AM
That's how this all started. I went at the epoxy potting material with a ball burr on my dremel and never saw a resistor. After I got the material cleared out I didn't see any way to bridge the two contact points with a suitable piece of material. I also like the idea that I'll be fashoning the contact out of a single piece of 1/16" brass and will be able to change it when it wears out. Like I said, I'm hoping that what I recieve tommorrow will be the non-resistor type of rotor. I can see where as more of us switch over to the MSD CDI we will be needing a supply of rotors. Warren
LEAKYSEALS951 05-08-2014 09:42 AM
oreilly rotor- no hoping involved!
http://forums.pelicanparts.com/uploa...1399570900.jpg
wolds 05-08-2014 09:45 AM
Tried that, no joy. Warren
LEAKYSEALS951 05-08-2014 09:46 AM
really? what happened? Mine worked. Just curious... (actually don't tell me- I dont want to jinx myself!)
Ron
wolds 05-08-2014 09:58 AM
If you have your local FLAPS run that number it comes up as a resistor type rotor. I ordered two rotors yesterday through amazon manufactured by Standard. The picture shows non-resistor type, hopefully that's what I'll recieve tomorrow. What I'm doing here is just a "plan B". Warren
john walker's workshop 05-08-2014 10:02 AM
napa. echlin brand.
The cap'n 05-08-2014 10:05 AM
"Standard" parts would be second rate if only they were better. They're, in general, cheap junk. I've personally witnessed total meltdown of their caps and rotors in less than 50 miles.
The Cap'n
wolds 05-08-2014 10:12 AM
I've already gone down that road checking with Napa as a result of reading previous threads on the subject. That PN refers to the resistor type rotor, it's what is depicted in their catalogue. I think somewhere along the way they have changed their manufacturing specs. Warren
LEAKYSEALS951 05-08-2014 10:28 AM
I hope your part works tomorrow. I ran down the same road with NAPA myself. I was in oreilly not 6 months ago and they entered "1978 911 sc" and it came up with three rotors, a resistored rotor (the one they recommended)and two resistorless (one of which was NLA and the other was this exact part #. The computer actually had pics of the part numbered rotors and you could see the resistorless feature on top. I ordered that # and got exactly what was pictured. I hope they haven't d/c'd that one as well... I might just go by there out of curiosity and check.
Good luck
R
wolds 05-08-2014 10:35 AM
I'm thinking that someone should market the non- resistor type. As time passes there will be more of us going the aftermarket CDI route and a demand for this part. My Permatune gave up the ghost on the way back from Hershey last month. I've been running on a borrowed Bosch while I gather parts for the upgrade. I've got an MSD Streetfire CDI and Blaster high vibration coil to install. Warren
K Sykes 05-08-2014 12:18 PM
Don't cut off the tip or the center and solder some copper wire between the two, and bed it in some epoxy. I did that when I was running MSD and it worked fine. I'll see if I can find mine and send a pic.
wolds 05-08-2014 05:03 PM
As you can see from the picture above I've already done that (no harm no foul) it was a used rotor anyway. We'll see what arrives in the mail tomorrow. Also, I spoke with a associate at O'reilly auto parts, he has a BWD D-703 and a Masterpro 2-3114 rotor that may work. Otherwise, I'll continue with my little project. If all else fails I'll try the bridge wire approach bedded in epoxy. If I take the bridge approach I'll share some pictures. Thanks for the help. Warren
wolds 05-09-2014 04:06 PM
So I received my rotors from Amazon today and am happy to report that they are the non resistor type. The box says Intermotor PN GB330. made in Mexico for what it's worth. Once I get the MSD Streetfire installed I'll post some before and after waveforms of the Bosch vs MSD for future reference. Warren
wolds 05-09-2014 04:18 PM
Here's a picture of new rotor and box. Warrenhttp://forums.pelicanparts.com/uploa...1399681066.jpg
garrett490 05-12-2014 05:39 AM
Sorry but what's the advantage of doing this? Lower cost parts, better performance??
wolds 05-12-2014 06:48 AM
This all started when my permatune went south and I was in need of a replacement. I purchased an MSD Streetfire CDI and Blaster coil as a replacement. The stock resistor rotor is not up to the task of pushing 45Kvdc to the cap so you need a non-resistor rotor. My attempt to modify a resistor style rotor to non-resistor became a mute point when I recieved my non-resistor rotors in the mail last friday. Warren
T77911S 05-12-2014 08:49 AM
i have been using stock rotors with MSD for over 10 yrs and no problems. i have also put in 2 MSD's, one with points and one on my 930, never had any tach issues that i hear about.
Bob Kontak 05-12-2014 09:00 AM
MSD installed maybe eight years ago. Stock rotor.
Only think I notice is a build up of a gray crust on the cap contact points after 500 miles. I dremel or lightly scrape the stuff off and the car runs smoother.
I don't remember this with the Permatune(s) but it has been a while.
Not sure what it is from or if normal. There must be something amiss as the issue would surface in the forums.
wolds 05-12-2014 09:04 AM
Just to be clear I'm not having any tach issues with my car. I am being preemptive by using a non-resistor rotor. I have seen plenty of theads on the subject of resistor rotors. The nail in the coffin was that MSD does not reccomend the use of resistor rotors so why take a chance? Warren
Bob Kontak 05-12-2014 09:25 AM
I am changing mine out ASAP to non-resistor.
I am sure I read the warning years ago but assumed that I did not have a resistor rotor.
I have been looking for my old spare to test ohms to be sure. It should show some resistance, right? I sounds reasonable but anytime I think I know what is going on with electricity.............
john walker's workshop 05-12-2014 09:27 AM
echlin # EP407 @ napa.
wolds 05-12-2014 10:04 AM
I'm good to go, picked up 2 on Amazon.com. FYI, when I called Napa regarding the EP407 the picture in their database showed a resistor type rotor. Not sure what you will get if you order one. Warren
tirwin 05-12-2014 10:45 AM
FWIW, this part is not something the local stores have. I wanted to get a couple and went online to try to have the parts shipped to my neighborhood store. It was going to be a $10 transfer fee from two different stores so they suggested it would be cheaper just to buy it online and have it shipped to my house.
tirwin 05-12-2014 11:09 AM
Here is a picture of the Echlin #EP407.
http://s7d9.scene7.com/is/image/Genu...Company/486352
I also found this as well... wonder if it would work? But it is bit pricey...
Bosch 04-008 Modified Rotor (NO RESISTOR), Fits 010 and 019 Distributors, 04-008M-1-234-332-088 - Aircooled.Net VW Parts
It sure would be great if Pelican carried a bona fide resistor-less rotor.
Bob Kontak 05-12-2014 12:25 PM
Thanks!
Just ordered a few from NAPA. $5 each and a few bucks shipping from their (I think) hub in Richmond VA.
Interesting how many cars run this rotor. Look under more applications if interested.
EP407,ECHLIN EP407 Rotor for ALFA ROMEO,BMW,FORD
