-   -   Bulb Holders for Turn Indicator in Tach (http://forums.pelicanparts.com/porsche-911-technical-forum/810331-bulb-holders-turn-indicator-tach.html)
pitsqrd 05-08-2014 07:01 PM
Does anyone know what the part number is for the bulb holder for 1.2W turn indicator bulbs in the Tach and where I can buy a couple? One of mine from the 78SC disintegrated when I pulled the bulb out of it.
I purchased a set of "bulb holder (dual pole, small bulb)" 999-632-009-10-OEM from our host that I thought were the replacement parts but these are for the 2-4W bayonet type BA7 bulbs I think. Too big for the little indicator bulbs.
If anyone has this information I would appreciate it. I need the bulb holders to finish a full LED conversion of external brake, reverse, parking and turn signal lights and internal instrument and indicator lights.
Thanks in advnace
pitsqrd 05-10-2014 09:25 AM
Could really use some info. No one else has had to buy one of these?
K Sykes 05-10-2014 09:49 AM
I don't have the part number, but I was able to get a part from the dealer that is the supurceded version. It's plastic instead of aluminum, and I had to sand it down a bit to fit. I made the same catalog mistake you did.
NYNick 05-10-2014 10:00 AM
I wish they made LED's for these.
pope 05-10-2014 11:11 AM
For LED's, check out this thread.
I think there's a solution in there.
E Sully 05-10-2014 11:31 AM
Looks like item 11 in the PET. You could try a WTB ad in the Parts Forum.
999 632 007 00, 999 632 009 10, or 999 632 002 00 (82-)
http://forums.pelicanparts.com/uploa...1399746512.jpg
pitsqrd 05-10-2014 10:12 PM
Thanks guys, I will check the dealer to see what they have. NYNick they do make LEDs for replacement. That is what I am going to use.
