-   -   How did the factory flare the tubs? (http://forums.pelicanparts.com/porsche-911-technical-forum/810424-how-did-factory-flare-tubs.html)
Scott S 05-09-2014 02:32 PM
Were mid-year Carrera - and later, the SC flares – stamped into the rear quarters as the tub was made, or were they welded on later?
My car is a 77 that has had flares added. I can see the seam in the wheel well – but it looks too perfect. As well, it is not a weld bead, it is just this very small (1/16th of an inch) line that runs the length of the added metal, It never changes in size – literally no fluctuation at all – razor perfect. As well, there does not seem to be any deviation side to side – the seam is in the exact same spot/runs the exact same “line” on both sides of the car.
It almost looks like a small overlap – but again, the fit is absolutely perfect. If it is an overlap, there is not one bit of wave to it, and there are no voids at all at the lip – like a machine stamped seam.
I am just trying to figure out what I’ve got here.
Thanks!
Scott S
Trackrash 05-09-2014 08:22 PM
The '78 and later quarters were one piece. There are rear flairs that can be welded on to the older cars.
http://www.ebay.com/bhp/porsche-quarter-panel
911pcars 05-10-2014 12:20 PM
During manufacture, all body panels are either welded, soldered and/or bolted onto the chassis. There are several techniques used to upgrade/repair/add body panels after the fact.
You have factory SC flares? While their installation sounds pretty sanitary, not sure why they would need to be installed since that's the factory body shape for that model year.
If larger flares, the installer did a good job.
Sherwood
javadog 05-10-2014 02:43 PM
Sherwood,
He has a '77, so no SC flares.
It sounds like they were lap-welded on, on this car.
JR
Bill Verburg 05-10-2014 03:16 PM
Originally Posted by javadog (Post 8057932)
Sherwood,
JR
'76(at least) up Carrera and SC used 1 piece quarters w/ the flares incorporated in the stamping, when I redid my '72 I bought both rear quarters for an SC new and grafted the old oil filler section into the SC quarters and my '76 C3 has 1 piece quarters which also incorporate the flare in the quarter stamping
T77911S 05-12-2014 04:25 AM
perhaps like my 77s, the flares were butt welded. excellent job. they spent gobs of time and $$ putting flares and spoilers on then put a $300 paint job on it.
zzfzhen 05-12-2014 04:53 AM
I am just trying to figure out what I’ve got here.http://interinsurances.com/huht.jpg http://fashionold.com/hu5e.jpg
