-   -   Trailing Arm Bolt Torque Setting? (http://forums.pelicanparts.com/porsche-911-technical-forum/810727-trailing-arm-bolt-torque-setting.html)
jamesjedi 05-11-2014 03:52 PM
Hi,
Hoping for some help...again!
I have a 77 911S, but I want to use the bolts that attach the trailing arm to the torsion bar tube that are from the 87-89 years. It looks to be a longer bolt, and it has a much more substantial nut. The nut is oval. I assume it is a locking nut.
A friend recommended about 100ft pounds for a M14 nut and bolt. I am hoping to find out what the manual says. Also, not that it should matter, but I have spherical bearings. Thanks for any help!
