The strongest rear end we ever found for racing was the Detroit Locker.
It effectively makes it a locked differential if one of the wheels slips. Very strong, easy to set up, and uses regular lube. BUT....this type of diff is very loud...very hard...and can be anoying at low speeds. When entering a corner at lower speeds...if you down shift while turning...the diff will lock and unlock several times....sort of a clunk/click/clunk/click sound...with a lighter car can even make the car jump a little which would not be good for corner traction. The only other option I can think of is a spool type. Bob |
Guard, ZF, Quaife, Giken, Kaaz, OBX .. pretty much in that order.
| All times are GMT -8. The time now is 02:30 PM. |
